Hi there.
This is my first O/C attempt and I just wanted to post about it and see if anyone had any feedback.
I have a 3.0c sl6wu (I think that's right, but it definitely ends in u) from Indonesia I believe (I'm at work so this is off the top of my head). I got it from newegg and am quite happy. I read about O/C and while I don't know if I'll actually run the computer at O/C settings I still wanted to try my hand at it.
So using the 3.0c, some AS5 and the stock HSF it came with I entered my bios. I manually changed my DDR latencies to 3-4-4-8 to allow some room for the O/C and raised my DDR voltage to 1.85v. I have very nice PC3200XL DDR from Corsair @ 2-2-2-5. Then I changed my AGP/PCI thingy to 66/33. Then after some more prep I began manually altering the O/C. I started at vcore 1.55 but for no reason whatsoever upped my vcore to 1.5875 because temps at that voltage didn't go up and I figured that would give me more headroom. I then began to O/C my frequency from 200 going up in 2mhz increments. I got up to 222mhz running at 1:1 with the DDR before I called it a night. At 3330ghz my temps at start up were 52 and at idle 47.
So I guess I can still keep going.
I did have one question though... what happens if you ask it to do to much? Do I have to do the CMOS jumper thing or will it let me get into the Bios most of the time if it can't handle the O/C? Not a big deal I just want to know what to expect if I go too high.
So any feedback is helpful and appreciated. Thanks to everyone who has helped me thus far and all the great guides and advice.
