uhm, not making fun of you, but isn't that a $10 walmart returned desk/table you have holding up your $1500 monitor? )
Just got my NEC today, greatpicture, Overabundant/safe nice packaging in the box. I think it's the best monitor packing I have ever seen!
I was wondering if there is any 30" monitor that I can buy which allows to reduce its hardware color space to match the sRGB specs so that all my programs will show correct sRGB colors even if they are not color managed?
The Eizo CG301W implements a "full featured" color space emulation via Color Navigator but has no H-IPS Panel.I was wondering if there is any 30" monitor that I can buy which allows to reduce its hardware color space to match the sRGB specs so that all my programs will show correct sRGB colors even if they are not color managed?
No rubbish: The emulation works just perfectly. I have already posted the visualisation of the measured gamut in Lab and the deviations in DeltaE94 that reflect human perception accurately enough. Although I haven't tested the 30" version I can assure that the CGs just behave like a good non WCG display after the color space emulation with sRGB as target (the "sRGB gradation" also achieved - most non WCG don't have a possibility to achieve this TRC via their OSD). The accuracy (in direct comparison to a non WCG display) is finally in most cases even higher because there are no deviations like little "under coverages" (that can't be compensated even in a managed workflow). The electronic preserves tonal values in the "transformation workflow" so that banding is avoided. The FRC-dithering stage (to drive the 8-Bit panel and "preserve the through the electronic preserved tonal values") works well - that means inconspicuously.Emulation is rubbish.
A few things.
1. The question was: "Isn't it possible to hardware calibrate the 3090WQXi internal LUT with the Spectraview-II to display sRGB instead of Wide Gamut? "
The answer: No.
2. Want realistic colors? Get sRGB monitor. Period.
Apple.
Greetings everybody, this is only my second post. Xorbe is right. I purchased my 3090WQXi five days ago. The only difference bewteen the two 30 inch NEC models is just the software that is included. The hardware in each box is identical. I went through several days of frustration trying to get this clarified. Your serial number is how NEC knows which version you have purchased. Thanks to all of you for comments regarding this monitor. It was nice to know everything, good and bad, about the 3090WQXi before I purchased it.I don't think that is true. I read that the recent LCD3090W-BK-SV is simply the 3090WQXi bundled with SVII-PRO-KIT.
