LAiN_OfTheWired
- Nov 6, 2008
I've got a budget of about $100 with a little bit of breathing room (so $125 prolly isn't out of the question) but I *need* to get rid of the acrylic case I'm using now. The case simply does not breathe well, and some of the mounting pins for the motherboard are starting to give up on life.
My goals with this next case are to move to water cooling about a year in the future, but for the moment I'd like to keep and possibly increase my OC on air. Most likely I'll be running two HD 5000 series ATI cards with my GTX 275 being pushed over to physx duty come spring (unless a fermi card is cheaper than equivalent dual radeons and performs about the same or better). I'll be thus moving to a new PSU, and preferably my next case will have a bottom-mount for that. I do require at least a mid-tower, full tower preferred though (when hasn't extra space inside been a good thing?)
I've been looking at cases like the Azza Solano, Cooler Master HAF, Xclio Windtunnel... This is the first time I've been serious about a case just being more than a container for computer parts, though, so I'm not exactly sure what I should be looking for or if there are others out there that might be worth checking out, too.
So given the budget and tiny list of preferences, what would you guys suggest going with?
