NKDietrich
- Jul 25, 2004
Hey all.
Working on a new build. The only watercooling components I have so far are three EVGA Titan Hydrocoppers. Other than that, I'm still trying to decide how I want to do things. Here's my thinking so far:
I've got a Rampage IV Extreme. I'm not even sure if I want to water cool it. It would cut down on loop complexity to avoid it, and the available waterblocks for it don't appear to be compatible with 3/4" OD system. (Specifically I'm referring to the EK one.) But on the other hand, I understand X79 chipset can get pretty toasty.
Definitely not watercooling my RAM unless someone can provide a really compelling argument for it.
Haven't decided on a waterblock for CPU. I'm thinking Koolance CPU-380 or EK Supremacy.
Radiators. I am fitting 2x480s and 1x240. Thoughts on brand/model would be appreciated.
Tubing I'm thinking Norprene. I like the sort of industrial look and lack of plasticizer leeching.
Fittings, probably just go with some variety of Bitspower compression fittings.
Pump/Res, no damn clue. So many options here.
Setting up a nice drain port would be nice, not sure the best configuration there. Someone suggested a quick disconnect at the bottom of the loop and just having the other side of the disconnect attached to some tube sitting in a drawer for when I need it.
Anyhow, I'm open to any and all suggestions, as I haven't done a custom loop in 12 years.
