I have been looking to update my home network for a year now and keep putting it off. Meanwhile things are starting to get really bad. I had been using an SMC barricade router for a few years expect it didn't seem to be powerful enough to handle SPI but with it off the thing was great and reliable. But it has since died and I just garbed a cheap wired router to hold me over until I figured out what to do. But this POS can't seven handle Internet use for more then one PC. I get web pages timing out left and right when more then on PC is in use and can't even think about downloading a torrent.
I want to build a PC with off the shelf parts to run PSSence though I am open to other suggestions. I have never used BSD and to be quite honest I am not all that up to date on Internet security measures. But I learn best hands on so I am sure I will figure it out.
The problem I have right now is I am a bit overwhelmed by trying to select the hardware for this. I don't really want to spend money on something and find out it wont work. I also want to ensure the system I build can handle any and all future planed and even unplanned expansions of my home network with ease. I suspect that my needs now and in to the future really aren't all that demanding so this should be easy.
Ok so on to my network as it exists right now and where I want it to go with this upgrade. For Internet connection I have DSL while waiting on FIOS. I have no need for wireless so everything is hardwired. I am sill operating on 10/100 hardware but I would like to upgrade to gigabit. I have 2 primary computers used for web surfing and gaming. I have another box I used to download torrents and sees a bit of double duty as a NAS but that will probably be changing a bit since I have plans to introduce a WHS system for backups and networked storage. I also have a Mac and Linux system that will be on the network. I also need the ability to connect up to 3 random computers, these would be repairs for family and friends. I would also like them to operate on a heavily restricted access level for safety. Other then that I would just like to be able to either 2 HTPC or media extenders when I get around to upgrading my TV's. A VPN to access my network when away from home and maybe a small dynamic DNS FTP / web server for personal use.
So to sum that up.
Right now:
DSL connection
10/100 router and network
4x personal computers (2x windows, 1 nix, 1 Mac)
1x torrent box / NAS
up to 3 random computers being repaired.
Future:
FIOS
10/100/100 network
4x personal computers, same as above
1x torrent box
WHS for backup and NAS
up to 3 random computers being repaired, hopefully with heavily restricted LAN and WAN access.
VPN
Small personal dynamic DNS, FTP and web server.
2x HTPC or media extenders
I am open to suggestions for hardware but for compatibility and reliability I am inclined to go lintel whenever possible for this build. What I am looking at right now is a Celeron 430 1.8GHz, 35wm about $40. I know it's totally overkill but once I have a better understanding of PFSence and what I actually need, I hope to move to an embedded system and then I can use the Celeron system for something else.
But sadly this is where I get stuck. So many options for motherboards to pair with that chip and I am still rather unsure what is supported. I am not against going with a full ATX board since I have spare cases and like I said this is really only going to end up being a temporary PFSence box that will get re-purposed. It also doesn't help that I can't even seem to figure out how many network connections this box will actually need to do what I want.
So I am off to see how current BSD support of Intel chip sets is. While I am looking at that I was hoping some of you could help me out with advice on how best to wire things up for my needs and what I will need as far as NIC's and switches. I am trying to search around the net to figure this out but my current networks reliability is not helping. Once I have the hardware and my 2 primary computers up and running with a reliable network I am sure I will be able to work the rest out much easier.
Thanks in advance for any help and advice.
Tom
So to sum that up.
Right now:
DSL connection
Future:
FIOS
10/100/100 network
1x torrent box
VPN
Tom
