I'm in the USAF and am deploying to the desert for ~3 months toward the end of August. I want to get a 15.5" laptop primarily for gaming and DVD's. I will be using it for my frequent TDY's throughout the year as well when I return. I'm trying to keep it around $1500 but not to exceed $2K. I want to be able to play Oblivion and Bioshock well (hopefully not delayed before I leave) and even Crysis later on in the year. Practically anything I get will be better than my current desktop (see sig) so this laptop may become my main gaming PC for a while. My wife also can't understand why I need to spend so much and not just get a $500 Toshiba like hers. This means my laptop must be powerful for games since I won't be building a new gaming only PC like I was planning on. I will have my own little "room" with power "over there" so charging a laptop isn't a problem.
I was originally thinking of getting the Asus F3SV-B1 (http://www.newegg.com/Product/Product.aspx?Item=N82E16834220162) which just came back into stock at newegg but now I am considering 2 other choices:
The Asus C90S (http://1toppc.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=C90S) since it is basically a portable desktop PC and is upgradable. This could help in making it last longer as a replacement gaming rig. The only downside is it has horrible battery life.
The Asus G1S-A1(http://1toppc.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=G1S-A1) It's basically the same as the F3SV-B1 except with an 8600GT (vs 8600GS) and a slightly faster processor. It also has a few other nice features.
All come with Vista (32bit though on a recovery and driver disk, not actual install DVD) but if I order through GenTech I can get 64 bit with DVD and they install everything for free. I do plan on getting XP 64 bit and dual booting as well due to all the people complaining about Vista's problems. 2 gigs of ram is a must as well. I am correct that 64 bit OS's are better or at least supported for Dual Core right?
Is there much of a difference between the 8600 GS and the 8600 GT? I have looked at GPU review and Notebookcheck but can't really get a good idea of how they stack up to my X800 Pro AGP card.
As of tonight I have the following prices with customization on GenTech:
C90S $1560
F3SV-B1 $1642 (edit, just realized it is 1440x900 res and 2ghz there vs 1680x1050 and 2.2ghz at Newegg)
G1S-A1 $1944
I have looked at the Dell 1520/1521 whatever and was not that impressed and with my "customization" to match the F3SV it was more expensive.
I would really like some help choosing and/or suggestions since I need to buy soon so I have time to play with it and install stuff before I leave. Thanks.
Cliffs for reminders:
3 Asus laptop choices
Gaming mostly
$1500 - $2K Budget
C90S $1560
G1S-A1 $1944
Gaming mostly
$1500 - $2K Budget
