To make a long story short I was having lots of problems with my main 1tb WD caviar black drive. My main OS partition got corrupted and refused to boot into windows. I originally had 9 pending bad sectors then after running HDD regenerator I had 9 uncorrectable bad sectors and after running WD DLG I now have 4 uncorrectable bad sectors. I need to note that before running HDD regenerator WD DLG completely failed the tests so as a precaution I also changed ports and sata cables and have been running with the drive for the past few days.
Here is the complication. I applied for an advanced RMA because I was convinced the drive was bad and I was lured by the prospect of getting a newer drive with 64megs cache and 500gigs/platter. Miy drive is old and only has 32megs cache. I have not even opened the box yet because I have also read of people getting refurbs that break down a couple of months later.
Thing is I need all my sata ports so how do I know if my sata port is bad, or cable or harddrive? Should I go ahead and open the box or send it back to WD?
