I'm planning on painting some parts of the WC box I'm working on and I want to know which ones are good enough for acrylic. I saw Krylon(sp?) at acehardware and says it can paint plastic but I don't know which ones. And do I need primer too b4 applying the real paint. I've heard of spray paints that doesn't need primer if someone knows will you tell what they are called and where to get it.
I appreciate all the advice you guys gonna give.
