I've been building PCs for quite a while but never actually set up a HTPC. I finally got a "let's look into this and maybe do it" from my wife so I need some advice from people with experience. First off, I plan to build it using my old hardware:
Lian-Li PC-60b case
AMD PII 550 w/ mobo
AMD 4870 vid card
4gb RAM
Win 7 home (32 bit, because I already have an extra copy)
Problem 1 - Ripping
Originally I tried to just copy the files from my dvds to the hard drive because I want to preserve the menus, full surround sound, and full quality. I'm not interested in degrading the quality of my movies because I spent a good deal of money on my home theater system, and I want to keep the full high-def sound and visual experience. When I tried to play it in Media Center though it came up saying it was not formatted properly (DRM issue I think). I used HD Decrypter from DVDFab to rip a test disc at full quality, and it seemed to work. I haven't used it on the HT system yet so can anyone let me know if this actually keeps all the goodies like 5.1 channel sound? If not, can you recommend a good program (preferably free) that will? I have probably about 900 or so discs that I'd eventually like to put into the server so I won't have to mess with the discs anymore.
Problem 2 - Connectivity
My original plan was to use my main rig as a file server and just stream the video to the HTPC over my home wireless network. I've been reading though that a normal home network won't provide enough bandwidth to stream full dvd quality. What would I need to do to make this happen wirelessly or would I be better off just putting the storage drives in the HTPC itself?
Problem 3 - Programs
Right now I'm looking at controlling everything with Windows Media Center and the Media Browser plugin. Is there a (free) program out that is better for cataloging and browsing a large selection?
Problem 4 - Control
I have a Logitech Harmony One remote that I'd like to use to control the media player. From what I gather, it can be programmed to do this providing I get an IR receiver for the HTPC. Is anyone using a One to control their HTPC? If so, how did you set it up?
I'm sure I'll have more questions as I work on this but I appreciate any help/advice you guys can provide.
Lian-Li PC-60b case
AMD PII 550 w/ mobo
AMD 4870 vid card
4gb RAM
Problem 1 - Ripping
Problem 4 - Control
