CrashGawker
- May 30, 2002
I've got a pair of 250GB Hitachi Deskstar SATA hard drives that I had in a striped array using the Promise onboard raid array on my old Chaintech Zenith Ultra motherboard that died last year. I recently finished my new computer and dropped the drives into it on the Asus K8N-e Deluxe's Silicon Image RAID array and rebuilt the array thinking it would rebuild the array around the data like the promise did. When I went to windows to see if the drives showed up, it didn't so I went to disc management and reinitialized and partitioned it.
I know that I probably really screwed up but since at no time would I let ANYTHING format the drives I have to hope there is SOME way of recovering my data still. I'm currently using Raid Reconstructor by Runtime to "rebuild" my raid array into a series of image files that supposedly will be compatible with Runtime's GetDataBack and in theory I should be able to get everything back...however the image creation process is taking AGES due to the size of the drive space involved and I was wondering if anyone knew for sure wether I will be successful or if anyone had other suggestions for retrieving my data. I'm sure some of the data could be replaced but I'm not holding my breathe so I hope that I can indeed retrieve my data unharmed. I'm becoming dissillusioned with RAID on the whole I think...seems it should be more intercompatible with different manufacturers using the same standard
