Edit:
The issue has now been fixed, I just went back to the "old and trusty" 91.45 drivers and everything is fine. I think perhaps 93.72 have some issues, but I wouldn't be surprised.
Ok, I'm using 93.72 drivers, and this is w/ a 7950gx2 and it is set to multi-display instead of the regualr multi-GPU so I can use dual displays.
Now I have a big ol' 21" CRT and a 17" LCD side by side, and I want to run the CRT at 1600x1200@100hz and the LCD at 1280x1024@60hz.
Right now, it's horizontal span, so it's using 2048x1024, which is sorta annoying, since a CRT isn't 1280x1024, but rather, 1280x960-friendly.
So where's the setting? I used to do it all the time, each monitor having its OWN resolution, but now I don't see that option, I only see vertical span, horizontal span, and clone.
