The RAID version.
Yeah, so long story short, had one of the drives die (it's a RAID0 scratch disk)
I upgraded from the 2x500GB some time back to 2x1TB WD Green drives, no issues.
So I've pulled the drives back out, being RAID0, I'm not concerned about data loss, but I tested both drives, found the bad one, and have now swapped it with a Seagate 1TB spare drive I've got here.
I removed both partitions (via my main Linux system) and popped them both back in the drive.
Hooked it up to my Macbook Pro via FW800, and what i get is WD Drive Manager stating "<serial number of my WD Premium II> is faulty, contact WD Customer Service".
Lists 0 as capacity.
Hitting 'Info' shows:
Capacity: 0
RAID Setting: Raid 0
RAID Status: Bad
Disk A Serial: <disk sn>
Disk A Status: Good
Disk B Serial: <disk sn>
Disk B Status: Good
What gives? Do the drives need to be a specific partition map or ID?
Thanks!
Capacity: 0
RAID Status: Bad
Disk A Status: Good
Disk B Status: Good
Thanks!
