I am building a rig to essentially serve as a GPU supercomputer. It's sole purpose will be to perform work using raw GPU processing power. As such, I plan to put 4 7950s in it, and they will be at high utilization 24x7, so I want to watercool them.
This will reduce noise (fans running at high speed are very loud on most graphics cards in my experience) and cool them better than an air solution. Also, I want to be able to do this inside a computer case - several GPUs in close proximity = HOT.
I have wanted to foray into watercooling for a while but never took the plunge. I read through the basic stickies on several forums but I could really use some advice.
I have confirmed that EK makes waterblocks to fit the cards I intend to use (thankfully they are ref design cards.)
I spoke with the folks at FrozenCPU and they told me that I should use 4 radiators (that is, 4 fans - like 4 single fan rads or 2 duals or 1 quad.) They also suggested to me that I could run the tubing to the gpu waterblocks in such a way that the water would not be going from card 1->card 2->card 3->card 4 (My concern was that by the time the water reaches card 4 it will be warmer and thus cool card 4 less efficiently than card 1.)
If I want to set it up that way - so the water isn't going directly from card 1 to 2 to 3 to 4 - do I have to use 4 TOTALLY SEPARATE rads, or can I still use a quad or two duals?
Also, how can I determine which rads will potentially fit in my case? I am looking at this case - http://www.nzxt.com/product/detail/120-H630.html The description mentions "The H630 offers exceptional support for a wide range of liquid cooling solutions, including the ability to mount 240mm, 280mm and 360mm radiators in both top and front positions." But that would lead me to believe it can only hold 3 120mm fan radiators (or does it mean I could have up to 360 in the top and up to another 360 in the front?)
