chinspecial
- Sep 25, 2007
I've been wanting to get back into starcraft for a while. Right now I have 32 bit Vista Ultimate installed. Starcraft won't seem to start correctly. Once I load it up, it may show the loading screen or even get to the main screen witha ll the menus and such, but then it will pretty much do 1 of 3 things. It will either turn black, the colors will get all messed up and an image will freeze on the screen (like Kerrigan's face all pink and green), or a combination of the two. Also, all the sounds still work and I can move the mouse around and hear it mousing over the different menu items, so it can pretty much be considered a display problem.
I have tried running in every single different compatibility mode possible and still nothing. I did reinstall it one time and it worked perfectly, but then I quit out and patched it. When I restarted it it wouldn't work, so I tried again, and again, and again yet nothing. It has never done that perfect load up ever again.
I have an 8800GT with drivers as indicated by vista 7.15.11.7516 (I forgot exactly which I installed last). Rest of rig in sig, if need anything else. I read on some other places that nvidia drivers could be the problem, but I'm not sure.
I thought if anyone could help, it would be the people here at [H].
So please help if you can!
