My computer will freeze though the mouse cursor still moves and all the program still run, like for instance I will be playing music and without warning the pc will freeze though the music still plays but I cant select anything, if you do ctrl-alt-del then the screen will refresh with the task manager tab, but I still cant select anything after it comes up, only thing I can do it turn the system off.
Whats going on?
P.S I have this weird file called 16 dead.exe at start up, you can see it in the task manager for a split second, could that be causing it?
Whats going on?
