As the title states, I'm dealing a Dell Optiplex GX270 computer.
The computer is running the Intel P4 2.8ghz. According to CPU-Z
Number of CPUs 1
Code Name Northwood
Specification Intel(R) Pentium(R) 4 CPU 2.80GHz
Family / Model / Stepping F 2 9
Extended Family / Model 0 0
Brand ID 9
Package mPGA-478
Core Stepping D1
Technology 0.13 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 2793.0 MHz
Clock multiplier x 14.0
Front Side Bus Frequency 199.5 MHz
Bus Speed 798.0 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 2793.0 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
It's an HT capable chip. The OS appears to be the default Win2k Service Pack 4 install straight from Dell.
However, as CPU-Z also notes, only one processor is working.
The Bios of the motherboard is as follows
BIOS vendor Dell Computer Corporation
BIOS revision A04
BIOS release date 05/17/2004
Chipset Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. A2
FSB Select 800 MHz
I've updated it to the latest version, but only one processor is enabled in the OS. Now I've made sure that I've enabled HT in the BIOS itself, both in the A02, and A04 versions.
Now, I know for a fact that Win2K supports SMP as I have my Own P4 running on Radeon 9100 IGP with HT enabled, and I've run Windows update to get everything there. I
I've updated the Intel chipset drivers as well..
And the OS still only supports 1 Processor.
Okay, I know HT isn't all that performance enhancing, and this isn't exactly a computer going for gaming (not using IEG-II anyways), but it's driving me up the wall as I know that the chipset, processor, and BIOS support HT, but that I can't get it working.
Anyone here have some ideas?
( and yes, I know, DON'T BUY DELL. I didn't have a say in this PC purchase)
Number of CPUs 1
Code Name Northwood
Brand ID 9
Package mPGA-478
Core Stepping D1
Technology 0.13 µ
Bus Speed 798.0 MHz
L2 Location On Chip
BIOS revision A04
FSB Select 800 MHz
