Man this forum place rocks with mad/crazy good info! props to all here
now here what i need help on:
My setup up (its weak, but works for me) HP DC7700 small form factor with Intel Core 2 Duo E6700 Processor (2.66-GHz, 2 MB L2 cache, 1066-MHz FSB) and this is the memory i can use (per hp.com) The Intel Q965 Express chipsets support non-ECC DDR2 PC2-5300 (667-MHz) and PC2-6400 (800-MHz) memory.
So my question is, will I benefit from using PC2-800MHz memory instead PC2-667MHz memory? will my motherboard/cpu actually use the 800MHz or will it drop it down to some other "standard" MHz speed?
with my FSB at 1066-MHz what is best/ideal memory to use with my FSB combination?
Do motherboards/cpu only use RAM(memory) at one speed, or can they operate at various speeds in relation to the FSB? (like with my FSB @1066MHz, will it actually run my ram at 800MHz or 667MHz depending on ram type? Man some clarity here would be great as i am trying understand this stuff
btw, i do understand that if i mix memory speeds, the new speed will be the one with the lowest speed
mad props to all for helping me out
