Alright guys looking to build a budget system for someone.
Do all of these processors interchange with each other on the board (obviously if a board dor no support it) But generally they should? I know it sounds stupid but I have not build or worked on a system for ages and I do not keep up with it so much.
Thanks again.
http://www.cpu-upgrade.com/mb-Intel_(chipsets)/X58_Express.html
Also maybe there is another way to check interchange on sockets and processors looking to hop into a setup that I can upgrade if needed but not upgrade everything because I am super cheap.
Thanks again.
