OK, so today is going to be my 4th service call from Comcast, and I'm getting tired of it, maybe you guys might have some insight, because they sure as hell don't:
Every hour or so on average (sometimes every 10 minutes, sometimes only 5x/day), my internet connection will completely drop. I have to reboot my router and disable/re-enable my network adapter, and that usually clears up the problem. Normally, I'd attribute this to a router problem, but I've since swapped out the router, and switched which onboard network adapter I use. Comcast has also swapped the modem, nothing has helped. Lately, however, I've had to reset the modem as well, and it takes multiple resets to get everything going.
In my modem log, I find a TON of entries for this:
No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.0;
And the entry dates for the log entries go from Jan 1st, 1970 to today's date, randomly.
In addition, my speeds have gone from a consistent 22mbps to about 10 at most, often dropping to about 2, and at worst, about 750k.
Comcast has gone from telling me that my signal is horrible, to now telling me the signal is fine, to saying that this is a problem on my end. Anyone have any insight?
