Sharing applications is another can of worms. The process for each application can vary, can you explain more what you want to do and what applications?talley said:that would work fine for the data.
any suggestions or ideas as to what i would look into for the shared/centralizes application ting?
As Phoenix86 mentioned above, your not going to be able to centralize applications. It's not feasible. As far as user profiles, you could use roaming profiles, but you'd need a dedicated server to handle this, and it's not really something to do in a home setting. I'm not trying to be an ass here, but if I was you, I'd take a step back, stop flying off after every buzzword you've read in other threads today, and take sometime to think rationally about this. I'm all for making things easier for non-computer-literate people, but there comes a point where what you want may not be feasible, and your best bet is to educate the users instead of setting up some enterprise-level configuration. I'm also all for learning how to do things, but you first need to slow down and decide what's rational and feasible.talley said:The kinds of applications are things such as quickbooks, anytimer, word, excel, photoshop, etc. the way your describing does sound a lot simpler and much more sensible. what about for the users profiles, is there a way to centralize them? also, i wouldnt mind and suggestions/links to search terms for information about centralizing everything as i'd like to learn about it and have no idea where to start.
djnes said:As Phoenix86 mentioned above, your not going to be able to centralize applications. It's not feasible. As far as user profiles, you could use roaming profiles, but you'd need a dedicated server to handle this, and it's not really something to do in a home setting. I'm not trying to be an ass here, but if I was you, I'd take a step back, stop flying off after every buzzword you've read in other threads today, and take sometime to think rationally about this. I'm all for making things easier for non-computer-literate people, but there comes a point where what you want may not be feasible, and your best bet is to educate the users instead of setting up some enterprise-level configuration. I'm also all for learning how to do things, but you first need to slow down and decide what's rational and feasible.
Phoenix86 said:Yes, and no.
Yes, it's possible with solutions like citrix/terminal server.
No, it's not really feasable for a home environment. Since you require a license/user or computer (depending on the EULA), centralized apps generally don't help with licensing (reducing # of licenses required) You are not going to be pressed for HDD space on your client machines, install the software locally. This will reduce network traffic, and make running program faster since the app data is local.
Why are you even considering centralized apps?
Phoenix86 said:Well, there's nothing wrong with doing things just to learn, but when that starts costing $, well you fill in the blanks...
Do you have a server OS? Are you willing to fork out $ for one? Got a fairly high powered system you can dedicate for this use?
Here's some info on terminal servers.
Basically you setup the server with the apps you want to share, then you connect to the server and it gives you a terminal desktop with access to the server's applications. It takes some horsepower on the PC to run multiple logins (since each desktop connection's processes are run locally on the server) as well as licensing for the server OS.
Well, if your basically just "testing" you don't need performance so much. RAM is everything in these setups, so starting a 1GB is good. I'd consider that a minimum for this type of task, but actual memory requirement can vary greatly depending on the use.talley said:I have legal copies of windows 2000 server and advanced server from some school stuff I did. I have a old p4 1.6 with 1gb of rdram that I can dedicate, and I maybe able to borrow some more slightly newer stuff if I need to. would that be grossly underpowered for the task, I realize it isnt very powerful. the schools in the area i'm in normally have pretty good student programs for getting ahold of stuff cheaper, although not everything is.
Considering your desired usages, that PC would be more than plenty to handle it. I have Server 2003 running at work on a dual 550 Mhz server with 384 MB of memory. It's currently a file server, web server, print server, and ghost server.talley said:I have legal copies of windows 2000 server and advanced server from some school stuff I did. I have a old p4 1.6 with 1gb of rdram that I can dedicate, and I maybe able to borrow some more slightly newer stuff if I need to. would that be grossly underpowered for the task, I realize it isnt very powerful. the schools in the area i'm in normally have pretty good student programs for getting ahold of stuff cheaper, although not everything is.
