Excuse my ramblings but it's been a while since I've been the board. I thing I registered somewhere around the time of ata/66 introduction back in the day... My old Abit IC7 Max 3 and P4 3ghz died on me a few weeks ago. I think the motherboard bit the bullet as graphics worked and mem did too. Searched around on here for a while at new projects and different setups and bought a few things. I'm not a hardcore gamer but plan to play more now as I got tired of it for a while and my old BFC 6800 OC GT wasn't going to cut it. Suggestions on a few games wouldn't hurt either.
Just curious what your thoughts are on this build I just completed. I'm running the stock OEM HSF but will upgrade that soon after I do more research on what will fit and work best. I plan to switch to another harddrive soon, along with adding in the others I have. Also what can I do with the horrible amounts of cabling on the PSU from corsair? shove it on the right side of the case behind the motherboard tray?
Asus P5Q Pro
MSI R4850-T2D512 (from hardocp review)
Corsair 750TX
Intel Core 2 Quad Q9450
G.SKILL 4GB (2 x 2GB) DDR2 1066
WD 640GB
Vista 64bit
Shoved in the "old" Coolermaster Wavemaster case
w/ old ide dvd and burner (need to order sata drives, suggestions?)
Original WD Raptor 30gb and 200gb regular WD
Any tips? Any on getting windows xp to not require authentication if I plug the old hdd in and boot from it, or is that just part of the game? I need to retrieve my FF bookmarks and a couple other things. If I can do that without booting from it, exporting them and saving them I'd love to.
Asus P5Q Pro
Corsair 750TX
WD 640GB
Vista 64bit
