Specialist[X]
- Oct 8, 2004
Hi I just built the new rig with specs in my sig.
I have checked that all the cables for the power are connected, the 24pin atx, the 2x4pin, and cpu fan wire. Coming from a DFI NF4 Ultra-D, I was surprised that this board had so little things to have to connect to from the psu. Anyway, so i tried both having just 1 stick and both sticks of ram in the mobo, trying to load optimized defaults or fail safe defaults, and letting it try to load into an older installation of windows from my previous setup (was going to format but i dont think it matters with 15 seconds). Anyway, it always seems to shut off after a few seconds without much of an indication why. according to the bios readings, the temperature was at 31 degrees when i checked. this is with the stock intel hsf too. I dont know what it can be, but one thing to make note of is that the push pins are extremely hard to get through the board 100%. it seems as if the pins are through about 80% but the back of the board shows that it isnt completly clipped. does this have anything to do with it? maybe its not making good contact with the hsf? that would not explain the temp readings then. whats also strange is that sometimes when it shuts off, it turns back on automatically right away after like 3 seconds. then fails again. rinse repeat. please offer what your insight may be. thanks!
