The pics are posted here
http://www.hardforum.com/showthread.php?p=1033285068#post1033285068
Started out life as a Stacker single loop. Then with the heat from the 4870x2 went to a dual loop with the PS relocated to the loop box stand. Disconnect a few electrical connectors and the vid card quick disconnects and 4 bolts holding case to stand and it comes apart if needed. First loop cools NB and CPU.
The pic of 1KW PS was just for fitting purposes to cut back panel etc (ie none of the bolts tightened etc). The cut was filed smooth for final assembly and a 1.2KW was the final PS used in the box. Have since added a 120mm variable speed fan to front loop box stand intake grill as rad fans and PS did not draw enough air into box on their own to keep box temps down.
