Hi,
I just put together my very first HTPC comprised entirely of old components. The specs are:
P4 2.4 Ghz
2x256mb DDR400
Abit IS7 mb
ATI Radeon 9700pro
16xDVD-ROM
30 GB Quantum HD
Old school ATI TV Wonder
All running MCE 2005 and being plugged into a 5 year old 26" TV. I don't have a remote for the PC right now, nor do I have a wireless keyboard or mouse. When I plugged in my tuner last night, I realized that ATI's TV app is really hard to function considering the low res of my TV. The video quality was alright. I would compare it to VCR quality. I was disappointed to find out that MCE didn't recognize the tuner so I wouldn't be able to watch/record through MCE.
So my question is: What should I do? I do plan on buying an HDTV (probably DLP rear projection) within a few months, and when I do so will be getting an HDTV STB from my cable provider (Rogers). Ideally, I'd be able to record HDTV broadcasts although from what I've been reading, that will be very difficult. First, I'd need MCE 2006 whenever that's out, then I'd need an HDTV tuner that supports cable card which isn't out yet either, and also, I'd need Rogers to support cable cards. Is that correct?
Sooo, the best tuner for the buck right now seems like the ATI TV Wonder Elite, or the equivalent Sapphire version. But, all I'd be getting for my $100 (CDN) is a tuner supported by MCE and slightly better picture quality. The remote apparently doesn't work with MCE very well, so I'd need to dish out another $40 for the MS remote or get a 3rd party program to use with the ATI/Sapphire remote.
I'm not sure what to do here guys? The system needs to be usable by my girlfriend who's not super technically inclined. ATI's TV software is therefore out of the question. Ideally, I'd like to be able to record HD eventually but if it's not likely to be possible, forget it.
Thanks,
Adrian
P4 2.4 Ghz
2x256mb DDR400
Abit IS7 mb
ATI Radeon 9700pro
16xDVD-ROM
30 GB Quantum HD
Thanks,
Adrian
