For $599 it can not be the IPS version. The IPS version will be $1200 or more.
Why do you think it should be $1200? LG is not NEC
NEC=Apple
it will be roughly that much because its an A grade 26" next gen S-IPS panel.
Is that confirmed? Could it be the same price as the Planar or DS? I'm thinking of getting the NEC 26 but may wait on the reviews of this panel.
I wonder if anyone else either has this monitor or knows what and how to use the EZ Zooming feature? I press the button, hear a tone, but then what?
Also even though Forte Manager was on the CD, it loads but the buttons are greyed out?
I have the W2600H-PF. .
W2600HP-BF is in stock in holland in 1-5 days but i have to wait till 25th till i can get mine :S
hopefully the repsonse time wont be that bad as the TN panels anyone can tell me more of improvements in response time from S-IPS compared to TN ??
yea some 24 inch aint that bad but more talking about the 25.5 inch and up which i heard most have horrible response time ...
The W2600HP (S-IPS) has an input lag of only 20 ms which can be seen on photos at http://www.forumdeluxx.de/forum/showthread.php?p=8765136&posted=1#post8765136
This is very good since it's less than 1,5 frames (16 ms=1 frame).
