Hello,
For some background you can check here
http://hardforum.com/showthread.php?t=1240086
Basically, my motherboard got fried so I ordered a new Gigabyte DS3L. While I was at it, went ahead and got new CPU. I wanted to transfer over my old system over to the new motherboard. The previous thread asks this and the simplest answer seems to be Windows XP repair console.
So, new board came in and everything is inside. When I boot, to the cd, I select repair, then it does it's thing and then tries to boot to windows. You see the Windows load up screen for about a second and it reboots. No beeps or anything. Then when it reboots it asks if I want to start up normally or safe mode, etc. All of them goes back to rebooting the system.
Any ideas?
Thanks
edit:
Just to clarify, I booted from CD, then selected Repair Windows, then it went to a screen where it said ESC to cancel or C for Windows. I hit C and it rebooted (right away), then it tried to go to Windows again. So, I switched the boot sequence to CD first again and now it in the Setup Screen. Not sure if it's stuck or doing it's thing. How long does it normally take to repair?
Any ideas?
Thanks
edit:
