snackcakeofd00m
- Jun 16, 2005
Ok, this week i just closed on my brand new house. The thing is that my new house is fully wired with Cat5e ethernet cabling. As i am sure you know means i can set up a gigabit network. My planning is to buy a gigabit router, a gigabit switch and a AP.
The way the network will be set up is <Internet>------<Gigabit router>--<Gigabit switch>--<AP>------Clients
The products i am getting are.
Gigabit router
http://www.newegg.com/Product/Product.asp?Item=N82E16833127060
Gigabit switch
http://www.newegg.com/Product/Product.asp?Item=N82E16817111020
WAP
http://www.newegg.com/Product/Product.asp?Item=N82E16833124179
So what do you think of my network. Any problems? Now of better hardware that is cheaper? all input is needed. thank you in advanced
Gigabit router
Gigabit switch
WAP
