Check this out:
http://firingsquad.com/news/newsarticle.asp?searchid=6891
Summary:
At this year's Quakecon (3 days away), Nvidia is going to launch their new chip, a 'mainstream' SM 3.0 card with SLI support for... get this... $199
Here's the kicker: The GeForce 6600 GT scores 8038 on 3dMark 03! (P4 3.2Ghz)
(Edit: That's with just ONE card, just to clarify, not in SLI)
That's right in the same ballpark as the X800 Pro, this is going to be killer. A $199 card that can hold its own with the $399 X800 Pro. AND you can run it in SLI, since the card has native PCIe support.
Not only that, you know this $199 card will be able to run Doom3 without breaking a sweat, because it's going to have the same fast Doom3 shader and shadow volume performance as nv40. So if it scores around the same as x800pro in 3dMark, that probably means faster Doom3 perf with the Nvidia architecture perks. Just think of the possibilities! You could spend $399 on X800 Pro, spend $199 on 6600 and get same (maybe a little faster) performance... or spend $400 on Dual-6600 SLI setup and get something faster than anything else available!
Summary:
