Big Fat Duck
- Jul 5, 2005
http://www.dailytech.com/article.aspx?newsid=3442
Press release for 740BX and 940BX here
Press release for 215TW here
Comments under the DT article confirm that the 215TW has HDCP
Samsung has unveiled three new LCD displays. Two of the new LCD displays are catered towards the commercial and business markets. The new SyncMaster 740BX and 940BX are 17 and 19 LCD monitors, respectively. The 740BX and 940BX are virtually identical with the exception of size. Specifications of the 740BX and 940BX include a 1000:1 contrast ratio, 5ms response time and 1280x1024 resolution. Both monitors have 15pin D-sub and DVI connections.
A height adjustable pivot and swivel capable stand is used on the 740BX and 940BX, though it doesnt support rotating features. The LCD is also compatible with VESA 75mm wall mounts too.
In addition to the SyncMaster 740BX and 940BX announcements Samsung also has a new 21 LCD monitor. The new 215TW sports a 1680x1050 resolution, 1000:1 contrast ratio and 8ms response time. Multiple video inputs are supported such as DVI, 15pin D-sub, S-video, composite and component video inputs. Picture-In-Picture and Picture-By-Picture are also supported by the 215TW, allowing users to view two video sources at the same time. The 215TW is also HDTV-ready too, though it doesnt say if it is HDCP compliant.
Pricing for the SyncMaster 740BX, 940BX, and 215TW will be $249.99, $309.99 and $549.99 MSRP respectively.
