silent-circuit
- Sep 18, 2005
What impact does the steel inside have on the case other than weight?
None. It might dampen sound a bit better (more dense than aluminum).
I know but five degrees difference in GPU temps is enormous. Note that the Haf932 crashed and the GPU was only one degree warmer than the FT01.
if you read the review, you'll note that the 100C was the peak temperature and stable, whereas the haf hit 101C and was still rising at that point. 4C difference is not enormous when you consider its 96 vs 100. In real world use, the difference would be minimal if any. The reality is that most users with the 1200 report lower temperatures because their case noise is so high, they can raise the fan speed of the gpu without a difference in noise since it's higher to begin with.
The point I'm trying to make is that the FT01 barely loses to a full tower with exceptional airflow and the FT02 is much improved in GPU cooling, so I'd expect it to beat it easily while also being much quieter.
firas, you could wait for tests to compare the two but I'd take the FT02 over the FT01 for sure unless you are an aluminum snob. I think as long as the black version had an all black interior it wouldn't really matter to me. The silver version is really quite beautiful in person though (talking about the FT01), and FT02 has an even cleaner front IMO.
I'll reiterate again blackstone, the tests showed that the 900, 1200, and the FT01 performed similarly, none overheated. More importantly, the stress tests are done with an ambient temp of 35C, which is 95F. I doubt anyone's computing area is that hot, unless you are gaming outdoors in the middle of summer or something.
I hope its not your TJ07's performance that is influencing your negativity here. http://www.custompc.co.uk/labs/238062/silverstone-tj07-w.html, though the 280 crashed in this case, I doubt you would still have your TJ07 if it was really that much of a problem. Remember this test was meant to show worst case scenario.
I wish there was some sort of nice Silverstone aluminum optical drive cover for this case. Lian Li makes one but I don't think it is compatible without modification. I love silver cases but it is so much harder to blend an optical drive with a silver case. With black the drives don't spoil the look nearly as much.
Lots of tigerdirect bashing on here. I never have a problem with returns or rebates. In fact they even cashed my mail in rebate when the manufactor denied it
I am only using a 8800GTX OC in my TJ07. I have no idea how it would handle a GTX295 for example. I did add a front 120mm intake fan for the video card however.
If FT01 can handle a GTX295 or dual GTX275s it is the midtower I would choose. I am very enthusiast about the Tower line of cases, I'm just concerned. I might be using both for some builds for other people and I want to make sure it will keep the graphics hardware stable.
I have two GTX260s and it handles them JUST FINE.
I took out the top hard drive bay, I have had no issues ever since.
The temps were perfectly managable with it in, just better with it out.
what are you idle temps on the 260s?..I'm wondering if my 2 caviar blacks are making my case hotter than having 2 gtxs. I suppose I should mention that my current setup is upstairs and my ambient is likely in the upper 70s-80s.
But seriously, when is the FT02 coming out?
FT02 I think is slated for August.
44 on the bottom GPU, 46 on the top GPU. The fan speed is all the way down to 40%, I can't hear them. I'd consider that fairly acceptable. They get up to around 65C under load, fan speed still at like 60%.
there needs to be more details/pics of this case released if its supposed to be out next month
You are right on that as normal sleeve bearing fans become noisier only when they are positioned horizontally to blow air up because they vibrate a lot in that particular orientation (this is not a problem if the fan is blowing air down). Noise caused by vibration aside, sleeve bearing fan is still quieter than ball bearing fan. So when we were developing the 180mm fans for the Fortress FT01 and RAVEN RV01 case last year, we spent quite a lot of time solving this problem, eventally we found that a custom spacer designed to fit between the C ring and the bearing cover did the trick and eliminated the vibration.
twich99, thank you for the suggestions. To answer your question, the retail 180mm fans aren't available for sale yet. There will be three 180mm fan models coming next month:
FN181 - black, fixed speed, 700rpm, 100CFM
FN181 - clear w/ blue LED, fixed speed 700rpm, 100CFM
FM181 - white, variable speeds, 500rpm ~ 1300rpm, 65CFM ~ 150CFM
The FM181 will have dual ball bearing while the other two will remain sleeve. We are fully commited to provide our customers with choices and support and that's why we are releasing three models at the same time.
We know that many of our customers have very strong preference for component selections, so the 180mm fan brackets in RV02 and FT02 all have mounting holes for 120mm fan. You are not bound to use only our fans in these cases.
That would be awesome. I have the FT01 and I would like some fans with a little more kick, should I need it.
