Alright guys, so far i havent bought anything but i was looking at these parts(keep in mind i am trying to keep this whole setup self contained in the case):
-DD 12volt pump
-athlon64 rbx block
-10 ft 1/2 inch tygon tubing
-dual 5 1/4 bay resevior
-maze4 chipset block
-geforce 6800 block* (hehe, i want it but cant justify paying that much for one right now)
-dual 80mm black ice radiator* (may change to a dual 120mm if a)i can afford it and b)if i can mod my case enough)
-various connectors and fittings
i have one of those alienware clone cases, y'know the ones just before those predetor looking cases came out, so i have a bit of room.
also, i have a bit of a OCD thing with cables, and i actually like to SEE my mobo, so cable routing is important(not water tubing, that i can understand being routed above my mobo)
oops, also forgot the routing sequence. is there a disadvantage to having the pump "pull" the water such as this:
res>rad>cpu>gpu>nb>pump>res(etc)
your help is greatly appreciated
-DD 12volt pump
-athlon64 rbx block
