I just finished putting together a new watercooled pc which consists of an abit nf7-s v.2, unlocked(week 6) athlon xp 2500+, dtek spiral block, c-systems(dtek) csp 750 pump, dtek pro120 radiator with evercool 120mm aluminum fan, and a dangerden round reservoir. I am using zerez super coolant mixed 1:20 ratio and everything is running fine so far at 2.2ghz @1.675 volts. I am idling at 38-40*C according to bios, nvidia sys util, and sandra, and sandra cpu burn in maxxed out at 47* C load. This isn't very much better than my thermalright sk-7 with smart fan 2 set up i just got rid of . This is with the case closed and I am using AS ceramique on the cpu. Just wondering what you guys thought about this. These temps are also about the same as when it was running at 1.83(stock) ghz and stock voltage. What could be wrong?
