mlapgw
- Dec 2, 2005
I currently have the creative x-fi titanium (non HD) sound card.
I use headphones almost all the time.
I also have Logitech x620 6.1 computer speakers plugged into the sound card. I know they likely aren't the most awesome computer speakers but they are only used occasionally so I haven't wanted to spend money to replace them.
The speakers have (3) 3.5 millimeter diameter TRS plugs which go into 3 color coded jacks on my current sound card.
I would like to get a better sound card and better headphones.
I have not figured out what will be better in that regard, a soundblaster ZXR by itself or a Titanium HD with a Schiit Magni.
I have noticed that which ever solution I go with neither card has the three color coded jacks my speakers plug into. Even though my primary listening will be headphones I do not want to give up the speaker option for when I have a buddy in the room. I have been reluctant to ask this question because some here can be rough when a newb type question is asked but...how do I hook up my old speakers to either of these cards?
