Nazo
- Apr 2, 2002
Hmm, I saw a refurbished X800 XT 256MB on Newegg for $218. A bit over. Still, if you're curious: http://www.newegg.com/Product/Product.asp?Item=N82E16814102492R
Anyway, I'm inclined to say go with the 6800GS. Frankly, ATI doesn't care much about mid-range or low end (especially not mid-range) and you want mid-range. Talking current gen that is. I'm just guessing that the 6800GS could have as much risk of this occuring as a 6600GT based on the fact that we're talking a rather different card here. The impression I have is that it has more to do with performance though. The 6600GT is a bit weak, but, it's kind of close to a 6800, especially with a good overclock, so that might explain why it gets a lower risk and occasional occurance of the issue versus a high risk on the 6800 series. Still, the 6800GS is different enough that I think you have a fighting chance. Also, if you make sure to get it from a good source, you should be able to send it back if it's not satisfactory (and I, for one, would consider buggy drivers causing jerking unpleasant playing to be unsatisfactory.) This isn't like where you knowingly void a warantee like by upgrading cooling, if a product doesn't do what it's supposed to do, you can legally AND morally send it back. Anyway, from what you said, I felt like you maybe thought the 6600GT has a high risk of the bug, but, it actually has a much lower risk than the 6800 series and only a few people have complained here and there about 6600GTs.
In this pricerange, nVidia now currently offers better choices IMO, not to mention cooler and quieter with the stock cooler (don't know what ATI was thinking with the cooling on the X800s and X850s, but, it sure gets loud and lets the card run hotter than what I at least am comfortable with since I want my card to last years. Not to mention that the temperature doesn't just shoot up in a hurry, but, it goes down in a hurry and rapid temperature changes costs lifetime like heat does.) The 6800GS almost guarantees an overclock so that it becomes at least equal to a good 6800 Ultra (the lowest 6800GS on Mentok's list has a 5.2K 05 score while the highest 6800GS has 6.7, versus the lowest 6800 Ultra getting 4 and the highest getting 6.9.)
