gigaxtreme1
- Oct 1, 2002
The other important thing to know about Threadripper is that the other two die apparently aren’t actually chips at all. They’re apparently structural inserts required for support, but do not represent “bad” Epyc cores or any kind of core recycling
End point, he thinks there could be more iterations of Threadripper up to 32 core. Some from AMD have already stated that there will be more TR products to come....
The thing that I read was that the X399 motherboards can't handle it
Sweet - if it's cost effective, why not? And if AMD releases 32 core Threadripper to give Intel even more reasons to get off of their collective asses and really push the envelope, then all the better.
Now all we need is someone to tell us which traces need to be pencil modded!
It is simpler to transform a 1900X into a 1950X than transform a 16C 1950X into a hypothetical 32C ThreadRipper.
And the possibilities for the first transformation are zero.
No Dummies please
So why is this a some kind of controversy?
I read the articles and didn't understand why its a big deal. The AMD engineer was saying that they aren't functional dies and from what I was reading they aren't even fully connected. Seems like a semantics issue getting blown way out of proportion, unless I'm missing more to the story.der8hauer originally found four dies on an engineering sample. AMD negated the existence of four dies on final ThreadRipper. AMD said to the media and also to der8hauer that ThreadRipper has only two dies and the other two are blanks. Der8hauer didn't believe the official explanation, purchased a retail chip and delidded it. He found that there are four dies in ThreadRipper.
Still wonder why AMD felt the need to blatantly mislead or lie about the make up of TR. Especially considering their terrible track record.
Because he got the other 2 dies working ? All he did was something which was pretty futile to begin with. He checked if there were dies then he realized that the dies that were in there he could not check anyway. So where is this lying part come from ? Have you already seen someone with 4 dies enabled or swapped the 2 functioning dies to the other 2 ?This topic is completely irrelevant for final users. For final users it doesn't matter if AMD uses four dies or two dies plus two blanks. It is relevant for tech enthusiasts and economic analysts. The first because want to know the fine details of the tech. The second because want to infer more about the economies behind EPYC and ThreadRipper.
If it was something completely irrelevant, then AMD wouldn't lie us in the first place, and guys as der8hauer wouldn't waste time and money on delidding and dismantling until the dead a ThreadRipper CPU.
You mean the bad track record Intel keep saying they are having, I would put as much faith into that as this https://newsroom.intel.com/chip-sho...d-one-of-the-worlds-most-ethical-companies-2/Still wonder why AMD felt the need to blatantly mislead or lie about the make up of TR. Especially considering their terrible track record.
Update: AMD has clarified that two of the four silicon die are 'dummy' blanks rather than disabled Ryzen chips. They are included for structural stability. The two die that are enabled sit diagonally from each other to aid in cooling.
How far would you go to prove a point? Well, the overclocker and CPU delidding expert der8auer has decided to put AMD's "Dummy Dies" claim to the test, to find out once and for all whether or not AMD is using failed/defective Ryzen dies or silicon spacers.
Then WHAT THE FK is the difference. Seriously are you guys that dense? It could be solid gold or a horse turd or real able Ryzen dies. Without traces and connects they all have the same outcome... THEY DONT DO SHIT!AMD initially said us that ThreadRipper has only two dies, and that the other two pieces were "blanks", not actual dies:
Der8hauer didn't believe the official explanation and tested it by himself:
Thanks to him we now know there are four ryzen dies on ThreadRipper.
Next logical step would be to check if those extra dies are fully functional or if those dies are failed dies. But checking this will be much more difficult.
Thank you for outlining this.AMD initially said us that ThreadRipper has only two dies, and that the other two pieces were "blanks", not actual dies:
At no point did I defend Intel. Funny how the amd fans jump on Intel. I was simply commenting on AMD and their misleading marketing /misinformation blunders toward consumers.
You did however used the same lingo as what Intel says about AMDThank you for outlining this.
Not a surprise.
But why did we have to hear this BS first.
It includes failed EPYC chips, plain simple.
They would have to duplex the memory channels though
Wow! Then AMD lied us when said there are only two dies on ThreadRipper.
This proves the true origin of ThreadRripper.
AMD dissembles about Threadripper
When der8auer earlier delidded a Threadripper engineering sample, he found, not surprisingly, four Zeppelin dies. At the time, according to Tom's Hardware:
AMD responded that two of the die on shipping Threadripper models are not the same as those Der8auer found in the engineering sample - the additional two die are "dummy" die that the company uses to provide structural stability for the package. These additional die prevent the IHS (Integrated Heat Spreader) from caving in when you tighten down the heatsink.
AMD continued to call the non-functional Zeppelins "dummy" dies after the retail Threadripper delidding, according to Tom's:
We followed up with AMD and inquired if the die were functional. AMD responded that two of the die are in fact non-functional "dummy" die that aren't connected electrically to the substrate.
This seems to be dissembling on AMD's part. Reviewers have typically assumed (as did Anandtech) that the "dummies" were mere silicon blanks, not fabricated Zeppelin dies.
I find it rather curious that AMD has gone to such lengths to obscure the fact that the dies are fabricated parts, working or not. Tom's concludes:
Mounting dies to a substrate is like any other manufacturing process; there can be defects. It's possible that the Threadripper processors are simply EPYC processors with die that weren't successfully mated to the substrate. Conversely, it's also possible that AMD is using defective die for the fillers, but in either case, it's doubtful that the company is wasting functioning silicon.
In fact I find the former explanation, that Threadripper parts are simply defective EPYC processors, far more likely. The reason is that even using defective Zeppelins for spacers is very inefficient from a manufacturing standpoint. The dies have to be mounted in some fashion as the functional Zeppelins are, and then they are soldered to the heat spreader as shown in der8auer's video.
That's a lot of work, especially the soldering to the spreader, for dies that are non-functional and won't generate any heat. Probably a simpler spacer scheme could have been devised, such as machining the spacer into the underside of the heat spreader.
This was in fact, the explanation I proffered on July 28, which apparently was so controversial. But the fan reaction to this probably explains AMD's dissembling about it. The fans don't like the idea that they're being sold EPYC rejects. They really shouldn't be upset. Threadripper is a perfectly reasonable way to salvage value from defective EPYC parts.
It is weird at the same time as well. There saying that there yield is awesome so how many of these failed dies are there before they have to resort to replace the failed dies with a placeholder.
Maybe not 4 GHz, but it should be easier for them to achieve higher clocks than Intel's big monolithic dies. And the cores are much more efficient in the lower 3.X range.The 16 core 32 thread 1950X is already $1,000. If you doubled the dies, you would have a greater cost. Threadripper already runs at the edge of the clock speeds it can handle with half that many cores / functional dies in it. You would double the TDP on that fucker which the TR4 motherboards almost certainly can't handle. Now, it's possible that it might work if they ran four dies at 2.0GHz or something like that but I doubt you'd be able to keep thermals under control at 2.8GHz or beyond if all four dies were actually enabled.
That doesn't seem likely if there are always the same two functional cores in TR.A nice resume of key points is found on seekingalpha article about this topic
https://seekingalpha.com/article/4107952-amd-threadripper-mysteries?page=2
"In fact I find the former explanation, thatThreadripper parts are simply defective EPYC processors, far more likely. The reason is that even using defective Zeppelins for spacers is very inefficient from a manufacturing standpoint. The dies have to be mounted in some fashion as the functional Zeppelins are, and then they are soldered to the heat spreader as shown in der8auer's video."
I get what your saying, and what's said in the above. I still think it's splitting hairs. Who cares if you are getting a failed Epyc processor or a purpose built CPU with two dies and two "blanks" in it? What the fuck is the difference? AMD has done this shit before, as has Intel. I fail to see how this makes any difference to us or anyone else. It doesn't alter how the CPU performs or overclocks. Chances are, using failed Epyc CPUs reduces the cost of Threadripper over a purpose built version.
