hey guy, i just installed Zalman 7700cu, jest another one about Zalman...my system's spec are in my sig...anyway on stock fan i had CPU temps at 50-52 no load....after installing Zalman they are the same 50-52 i thought it would drop about 10 degrees...i used AS5 at first than i tried the paste that came with Zalman with no results....i also try overclocking a little bit , to 2.4 but windows wouldn't even start...i think i installed it properly, although after mounting everything and screwing everything together the HS has a slight movement left and right is that normal? i can't screw it any tighter because there is no space really also i don't wanna break the CPU
any word of advise guys?
