ok my geforce3 is dieing and i got no money for a new card so like whats a good card for 30 dollars or could someone give me an old videocard?
i keep getting the blue screen of death and i got like 2 case fans and 4 40mm fans blowing air onto it but whatever i try to do to cool it off doesnt work you couldnt hold you hand on the card for more then a sec its so hot and i took the vmod off and it still crashes and i looked over the voltage points and yes everything is back to stock voltage even stock speeds. i got a pentium 3 heatsink on the gpu with a 60mm fan tyed to that. and yes the heatsink is sitting flat on the gpu and yes i know its the videocard dieing not something else.
it makes me so mad i cant do anything with my computer.
