kharan5876
- Oct 3, 2007
I looked on Norco's site today and now they have the RL-20 rails listed as compatible with the 4220 case. Has anyone tried these rails?
Way back when I got my Norco I got the RL-26 rails and like just about everyone else's experience, it was too wide for my rack and couldn't be used. I'm curious to know if this newer set of rails is any better and if it's possibly usable. Newegg reviews mention that it has a different installation mechanism and that you probably have to mount it on the inside. One guy says he couldn't get it work with the 4220, maybe hes right, or maybe he just couldn't figure it out.
So has anyone compared the 2 versions of the rails?
I have the gruber rails people have been using but I'd really like it if I could put the heavy case on sliding rails and not have to take it out of my rack to work on it. I'm willing to drill and dremel for it.
If you are one of the minority that managed to get your norco to mount with the original rails, which version do you have?
Finally, if you were able to mount it with the rails, can you slide the case out far enough to get the lid off and have it sitting out without having to worry about stability?
