The relevant pieces (all stock):
In BIOS I've raised FSB from 266 to 400, which should give 3.2 GHz (which is what it says in POST message). But ... when I get into OS, I see that the multiplier was lowered (from 8x to 6x), giving only 6x 400 = 2,4 GHz. What can be done about this multiplier lowering?
What I'm more worried about, is that the (generic) Patriot DDR2-800 RAM was (automatically) overclocked from 400 MHz to 500 MHz! I know, because of FSB, but is this too much?
BTW, the CPU temperature was raised from 38° to about 40°C (using HWiNFO software). Now, which software would allow you to also see the RAM temperatures?
Any other advice much welcome ... I'm not looking for an extreme overclock, just about say 3 GHz ... and with not melting the RAM.
EDIT: Would it be best to raise just the CPU clock frequency, while leaving FSB alone (or at least at max. 333 MHz) for the sake of RAM?
- C2D E6420 @ 2.13 GHz
- Asus P5K with latest BIOS (supports FSB @ 1333 MHz and RAM @ 1066 MHz)
- Patriot DDR2 800
