Mark305TBI said:That looks really good. How hard was getting the tubing on there with the boiling water?
xXxDieselxXx said:... you need to play a little bit with it and use some force from time to time... the challenge was the pump!
The difference in coolant temperatures from one point to the next in the loop is miniscule at best. Besides, you'd want the radiator to be able to dump as much heat from the closed system as possible. The radiator works best when the Delta T (difference in temp between the ambient air and the coolant) is highest. So you want the coolant to run through the radiator when it's at its hottest. That would be right after it went through the waterblocks.stormshadow said:hmmm...
you should consider re-routing and having your cpu or gpu cooled right after the radiator to take advantage of the coolest liquid...
looks great so far
Haste266 said:Originally Posted by xXxDieselxXx
looks great so far
meh - i'd still go radiator -> CPU -> GPUMark305TBI said:The difference in coolant temperatures from one point to the next in the loop is miniscule at best. Besides, you'd want the radiator to be able to dump as much heat from the closed system as possible. The radiator works best when the Delta T (difference in temp between the ambient air and the coolant) is highest. So you want the coolant to run through the radiator when it's at its hottest. That would be right after it went through the waterblocks.
good call - i think efficient loops are defitiely a priority - not only aesthetically but for flow as well...xXxDieselxXx said:According to plan that was what I wanted to do but then I really had hard time making the loop as efficient as possible with very little room in the case also keeping in mind the pump orientation I wanted the intake facing up to make it easier for priming.
One thing I learned ... next time I will use a fill port/T Line.... bigger case.
thats exactly wat stormshadow was saying, after the coolant runs through the cpu block, gpu block, res and pump, it goes back to the rad where it is cooled and goes through the same process againMark305TBI said:The difference in coolant temperatures from one point to the next in the loop is miniscule at best. Besides, you'd want the radiator to be able to dump as much heat from the closed system as possible. The radiator works best when the Delta T (difference in temp between the ambient air and the coolant) is highest. So you want the coolant to run through the radiator when it's at its hottest. That would be right after it went through the waterblocks.
LOL!! I love that.... gotta do that to my next set of ramsinks (if I use the Swifty ones)xXxDieselxXx said:Introducing Medusa..! The new RAM sink
Well guys what's the point of making your own loop if you can't customize here and there?
Petra said:LOL!! I love that.... gotta do that to my next set of ramsinks (if I use the Swifty ones)
InTheFlow said:I replied to ya on this over at xtreme but as a quick re-cap, make sure the 4 pin power connector is securely connected. Otherwise, the Asus board will not POST even though it looks like it is powering up properly.
SiGfever said:Will you take a picture of your motherboard with your power connectors plugged in?
ikellensbro said:Nice clean job there Diesel. Great log for beginners to look at, and some great hints at the end. If you are dissatisfied with your temps (doesn't sound like it at all), your best bet would be to upgrade to a 2x120mm radiator, as it looks like your CPU & GPU are putting out too much heat for your radiator to keep temps down as low as they could be. However, space is a bit of an issue with your case, and I'm sure you just want to enjoy your loop for a while now.
stormshadow said:sweeetness
great job diesel
Justintoxicated said:Looking good, reminds me of my own setup, only a bit different. I had to get creative with those swiftech HS and the Maze4 LP myself, bending alone was enough had to snip then down a bit
Only concern is the way your pump is located. When I put mine like that everyone told me I was going to have a hard time Priming the loop. never Tried it though.
