imzjustplayin
- Jan 24, 2006
I've had to do quite a bit of file recovery in the time I've worked with computers. The thing is though, I've never encountered any files that had any NTFS compression applied to them. Recently I decided to use NTFS file compression on unimportant files that are replaceable but that poses the question, does NTFS file compression make the recovery of files from a partially corrupted drive more difficult? If you have a compressed word document or text file, will it be more difficult to recover any usable amount of data compared the uncompressed file?
