x1600c said:sry. I had a typo it was supposed to be dual6600gt versus 6800nu
blazeking said:You mean SLI 6600GT's vs a single 6800GT?
I'm not sure about the 6600GT's, guess it depends on what brand you get. I'm running an XFX 6800GT on AGP, so if someone has some 6600GT's to compare this to, it might help: http://service.futuremark.com/compare?3dm05=688238
And check out this review, it's not too far away, and the comparisons might be useful: http://www.hardocp.com/article.html?art=NzE2
Andrew_Carr said:Oh, btw. Although I wanted to disprove someone earlier about 6600gt sli vs 6800gt sli, no one really says one way or another which wins. Still, you spend more on an sli board, and it's just less hassle to use one card. So that's an easy way to put the 6800gt ahead of the 6600gt's.
Also, if you want something that performs similarly o a 6800gt and is pci-e, you can spend 290-300$ on an x800xl, which is definately less than two 6600gt's and an sli mobo.
Chris Lakies said:Hey Stop using my score!!! Just Kidding!
My 3dmark
I'm using 2x Leadtek 6600GT's OC'd at 540/1200 & AMD 64 3000+ at 2.4ghz.
As you can see it looks like I'm doing fairly well against the Ultra's.
2x6600GT against an 6800Ultra
Chris Lakies said:I updated my 1st link because the other didn't work correctly. Check it.
