Im hoping someone can help here. I am trying to mod the hell out of a vanilla install of Oblivion. This is the Steam version. I have quite a few mods installed now but I am not having much luck. I have some missing grass textures so I am getting purple placeholders where the grass is supposed to be.
I figured I would check for conflicts and found I had a shitload of them. Not only that but Im not really to sure what Im looking at. I can CnP the conflict report if anyone thinks they can help. This is just a sample.
Im new to the whole modding scene with Oblivion so if this is something easy, dont be to harsh on me
Knights.esp] (unparented) - Active
No conflicts
[xulAncientRedwoods.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
Very minor conflicts
[xulAncientYews.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[xulArriusCreek.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[xulBeachesOfCyrodiilLostCoast.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
No conflicts
[xulBravilBarrowfields.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[xulBrenaRiverRavine.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
EDID 'AnimatedRiversV2TARLargeDownhill1' of record type ACTI conflicts with 1 other plugin.
xulChorrolHinterland.esp (Record type: ACTI) (Parent: Unique Landscapes Compilation 1.4.2.omod) (Active)
EDID 'AnimatedRiversV2TARLargeDownhill1Bend2' of record type ACTI conflicts with 1 other plugin.
EDID 'AnimatedRiversV2TARLittleDownhill' of record type ACTI conflicts with 1 other plugin.
EDID 'AnimatedRiversV2TARSteepDownhill1' of record type ACTI conflicts with 1 other plugin.
EDID 'AnimatedRiversV2TARStraight1Z' of record type ACTI conflicts with 1 other plugin.
[xulChorrolHinterland.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
xulBrenaRiverRavine.esp (Record type: ACTI) (Parent: Unique Landscapes Compilation 1.4.2.omod) (Active)
[xulCloudtopMountains.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[xulColovianHighlands_EV.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[xuldarkforest.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[XulEntiusGorge.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
[xulFallenleafEverglade.esp] (Part of Unique Landscapes Compilation 1.4.2.omod) - Active
EDID 'LODWaterPlane' of record type STAT conflicts with 1 other plugin.
xulImperialIsle.esp (Record type: STAT) (Parent: Unique Landscapes Compilation 1.4.2.omod) (Active)
