Hi all,
I built a new rig last week with the following components:
Mobo: EVGA nForce 680i A1
CPU: Intel E6600 Core 2 Duo
Cooler: Tuniq Tower 120
RAM: 4 Gigs (4 x1 Gig) G.SKILL PC-6400 5-5-5-15
Video: 2x GeForce 8800 GTX Video Cards
Case: Silverstone TJ-09 w/ two TriCool fans mounted on top
PSU: Silverstone Zeus 850W
HDs: Array 1 / Raid-0 2x 500 Gig WD SE 16, Array 2 / Raid-0 2x 250 Gig WD
Bios is P26.
AS5 was used in between the CPU and the Tuniq Tower.
I seem to have found a stable overclock and I'd like opinions on the temperatures. The E6600 is now at 3.6 Ghz, with a bios-set vCore at 1.50625. The RAM is matched at 1:1, 800Mhz, with timings reduced to 4-4-4-12. Voltage has been upped on the RAM to 2.0.
With vDroop, Speedfan and CPU-Z show vCore to max at 1.44. I ran Orthos for 9.5 hours w/o issue, and memtest+ found no errors. At idle, the core temps are in the low 30s, while during the nine-hour small FFT stress test, they didn't exceed 55C. By the end of the test, but before stopping, both cores were in the low 50s. Ambient air temp varied between 18-20C.
Anyway, I believe these are good results for a stable machine, and a 6600 @ 3.6Ghz is none-too-shabby. Opinions are welcome... P.S. I have plans to replace the 6600 with a Peryn in about a year, so I'm not too concerned about processor lifetime.
Thanks,
Mark.
Bios is P26.
Thanks,
Mark.
