kaluminati
- Dec 11, 2004
I'm new to overclocking, but I've tried to play it safe here. I've been using this as a guide:
http://forumz.tomshardware.com/hardware/Core2Duo-Overclocking-Guide-v1-ftopict197995.html
I've got it to boot up almost everytime, and have gone up to 3.2ghz. However it is unstable, and I'm pretty sure it's this ram. I have a big typhoon on the cpu, and the temp rarely goes above 50c, usually around 30-45, during load as well. Right now I'm at around 3.03 ghz, and it's been stable. I've run memtest and it seems okay. But any higher than that, and while testing the memory it either freezes or gives me an error while testing.
I've got the speeds at 5-5-5-12 v2.0. The guide says to put the v at 2.2 or 2.1, but the max for my mobo is 2.1, and I've tried that temp but still the same results. So I've put it back to 2.0 because I know this ram is rated at 1.9? Anyhow, have I gotten those timings wrong? I set the ram to the lowest speed before upping the FSB. DDR2-533.
I'd like to get it up to 3.2ghz, but can this memory seems it just can't take it I guess.
Specs:
Asus P5B P965 Pentium Extreme/Pentium D/P4/Celeron D 1066FSB LGA775 DDR2 + TT Big Typhoon.
Intel® Core 2 Duo E6400 Conroe Processor 2.13GHz, 1066FSB
Corsair TWIN2X2048-5400C4 2GB DDR2-675 XMS2-5400
Neatly layed out Antec p180, plenty of airflow.
2 HDs (one raptor, 1 250GB)
X-fi platinum
Athena Power 550 watt psu (please tell me thats enough)
eVGA 8800GTS
DVD/CDRW combo drive
Specs:
X-fi platinum
eVGA 8800GTS
