samborarocks
- Sep 8, 2005
Hey all,
Posting this as a last ditch effort for help....
I have an OCZ Vertex 60GB SSD in my machine. It's on the 1.4 firmware and I wanted to update it to 1.5->1.6->1.7 for the benefits of the update (mainly the 1.5 update as it adds 'garbage collection)....
Originally this was in a machine with an Nvidia based MB, the updater would never find the drive and from all I've read over the last year, the only solution was to put the drive on a different MB in order to update it (didn't have another machine to install it in, so I lived with the 1.4FW.
Now I've moved on to an AMD based Crosshair V. The drive is on the Asmedia controller. AHCI is on normally. I couldn't boot the Linux based ISO due to having a SATA CD drive, so I built a bootable USB flash drive, copied the firmware files over as described here... and set the controller to IDE mode -> http://www.ocztechnologyforum.com/fo...ta-and-FreeDOS
I can run the ssdchk.exe file and it builds the updater.bat file with the correct firmware, but once I run updater.bat, I get a message saying 'Not found drive'.....
Has anyone had any experience with this and how did you get the drive updated?
Thanks,
-SR
Thanks,
-SR
