I recently built a monster PC for details of that system view this thread
http://www.hardforum.com/showthread.php?t=891577
Anyhow I ran into another odd problem. I live in a rural area and dialup is my only alternative. The OEM Creative Modem Blaster I had in my old PC is good I tested it in my wife's pc and it works fine. However if I install either Modem Blaster (the one that was in my old pc or my wife's) it installs fine. XP has no complaints. However you dial up, you hear dial tone, it dials the number, it connects and the second it gets done initializing it immediately hangs up and gives me a popup box with an error 618 or 619 (I forget which exactly now).
I know for an absolute fact my username / password and dialup networking connection itself is setup correctly. I installed a crappy soft modem and it works fine just connects like crap. I'm adament about getting my old modem working because it was getting such good rates 48 or 49 kbps whereas the soft modem will only connect at 28.8 and the brand new encore I bought from newegg (which I thought would fix all this) can only squeeze out 33.6.
I know its a modem problem because my wife's machine can connect at these higher rates on the same phone line but using the Blaster modem.
I'm ready to just go out and try a NEW(ER) retail blaster to see if it'll work.
