FrozenLiquidity
- Aug 28, 2007
Ok, so here's the deal...
Back in about 1999 or 2000, I picked myself up a pair of Elsa 3D Relevator glasses(old page, don't trust all of the info) along with my GeForce2 GTS 64MB, which was just screaming back then. I had an absolute blast playing games with them, and did not suffer from the headaches and other problems that other people complained about, so don't go trying to talk me out of this.
Anyway, I still have my old glasses, as far as I know they still work. I still have the old cable. Hell, I still have the GeForce2 that I bought way back when. The thing is I don't want to use my GeForce2, I want to try some of the more recent games. I still have a fast CRT monitor that can pump out the refresh rates needed, but what I am missing seems to be a video card cut out for this task.
I guess I am just not as familiar with how this signal is sent by the card. So I want to know a few things...
Since these used a D-SUB (analog) signal, I expect that a DVI to VGA adapter which most cards use to connect to sources with analog input, would not work for these glasses. Is that a false assumption? I mean, if it does work then all I have to do is grab the DVI-VGA adapter, and plug my computer into an old CRT to start pumping out the 3D again. I have a feeling it's not that simple, but I am not sure, so I want to hear it from the experts who may know more about this than I do.
In the case that it doesn't work, and you need a card with a VGA D-SUB connector to do this, is it possible for cards like this (just an example, am not going to blow $300 just to play on an old CRT) to be used with the old 3D glasses because it does have that connector?
- If so, I suppose it's a matter as simple as finding a cheap and fast nVidia card that has the D-SUB style connector, and just using that. If not, then Plan C...
If neither of the solutions presented above are viable, then what is the best way to get these glasses back into action? What's the best card I can possibly use that is still compatible with these old glasses and can provide? I know it differs from the current system which is a dual-link card to a special dual-input screen capable of refresh rate of 120Hz. But if you're familiar with the old system or maybe have some experience with them working on more recent hardware, care to throw me a bone?
Thanks! <- Me with my old glasses on.
