I've done some extensive research, read lots of reviews (and lots of complaints), and here's the system I've arrived at:
Motherboard: MSI K8N Neo2 Platinum
CPU: Athlon FX-53
RAM: OCZ EL Platinum Rev. 2 1GB (2x512) DDR PC3200 (2-2-2-5)
Graphics card: Asus V9999 Ultra Deluxe
Waterblock: Dangerden TDX
HDD: Maxtor Ultra 250GB 7200RPM SATA
HDD: Western Digital Raptor 74GB 10000RPM SATA
DVD: Pioneer DVR-108
Sound: Sound Blaster Audigy 2 ZS Gamer Limited Edition
Mouse: Logitech MX1000
PSU: Ultra X-Connect 500W Ultra Modular Blue UV (http://www.frozencpu.com/cgi-bin/frozencpu/psu-108.html?id=Ay5IUZUv )
This is a change from the build I had been planning. Previously, I was planning to go with an Antec True550 PSU, no Raptor, Corsair XMS 3200XL Pro RAM, and a Visiontek X800XT PE graphics card.
There's still a bit over a month until I buy everything, but I'm not planning on going for any NF4 board if it's available, nor am I planning to get an FX-55 instead, unless I can find one for $800 or so.
Thoughts? Opinions? Anyone using a similar setup willing to provide real-world feedback?
EDIT: I just read an analysis of the TDX silver that shows little performance gain over the copper, and a higher PSI. Since there's almost $70 difference between the silver and the copper, I'll just go with the copper.
EDIT #2: I removed the low-end DVD-ROM I'd had listed, and replaced it with the spiffy Pioneer DVR-108 I just read about.
CPU: Athlon FX-53
