I have a P4 2.4B stepping B0, yes it's old and sucks. I am not buying a new processor so please don't suggest it. I have a ASUS P4P800 motherboard and it seems to have a voltage problem. Right now I have it set to 1.6V in the BIOS but it will fluctuate like crazy until I put the CPU under load then it smooths out to 1.6V. Right now as I'm typing this ASUS Probe is showing the voltage go up to as much as 1.664. Ok here is the question right now I have my P4 @ 2.8. I want to hit the 3Ghz barrier but the system rufuses to be stable from anything beyond this point. I want to raise the voltage to 1.7V but it seems that I read somewhere that after either 1.7 or 1.8 just slowly kills the processor. Can anyone confirm what voltage is safe to run this chip at? Also I don't know if it's my board or the processor but any .25V increase in the BIOS will not help. So basically if I want to go 1.7V I will have to try 1.7V. If I remember correctly the max temp this thing sees is 45C.
Thanks,
Stephen
Thanks,
Stephen
